The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
American Classic
Truck Parts
Fall is here!
Irwin A with a tip for engine swap
The last of the shows will soon be only digital pictures and fond memories. If you are getting your Bolt ready for some last cruises, or just thinking about putting her up for winter, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Loading
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
3 registered (Gabes-trucks, Cosmo, 1 invisible), 408 Guests and 4 Spiders online.
Forum Stats
39,284 Registered Members
48 Forums
104,820 Topics
Most users ever online: 910 @ Sat Sep 10 2016 09:53 PM
Today's Birthdays
35pickup, 68haywagon, Bubbles, buxman66, Franklin C. Cooley, Larry Shaddy, LimeyC10, mark8544, mike boyle, Pee-Wee, peter 60 stepsid
Image Posting Policy
New Reply
Topic Options
#985088 - Sun Nov 10 2013 09:55 AM Ohm resistance for fuel gauge / sending unit
chopperguy16 Offline
Loc: Ct.
Can anyone tell me if the ohm resistance for 1960-1966 is 0-30 for the fuel gauge.
Top
#985120 - Sun Nov 10 2013 12:09 PM Re: Ohm resistance for fuel gauge / sending unit [Re: chopperguy16]
3B Offline
Loc: B. C. Canada
Hy chopperguy16, I know they changed the sender and gauge from a 0 - 30 ohms to a 0 - 90 ohms somewhere in the 1960s. Classic Industries website lists 1964 and older as 0-30 ohms, and 1966 and newer as 0-90 ohms (I guess the 1965 vehicles didn't have fuel gauges). I did try looking in the parts book to pin down the year they changed, but with all the different models, each with their own sender I just got a headache, hope that info helps some.
Top
#985258 - Sun Nov 10 2013 08:21 PM Re: Ohm resistance for fuel gauge / sending unit [Re: chopperguy16]
Hot Rod John Offline
Loc: Central Colorado
Mid year 1966 they changed to 0-90 ohms
The previous models were 0-30 ohms
_________________________
Top
#985485 - Mon Nov 11 2013 04:37 PM Re: Ohm resistance for fuel gauge / sending unit [Re: 3B]
Loc: Ct.
thanks for the info 3B
Top
#985489 - Mon Nov 11 2013 04:39 PM Re: Ohm resistance for fuel gauge / sending unit [Re: Hot Rod John]
Loc: Ct.
THANKS FOR THE INFO HOT ROD
Top
#1007453 - Sat Feb 15 2014 11:56 AM Re: Ohm resistance for fuel gauge / sending unit [Re: chopperguy16]
mycajah Offline
Loc: Texas
Hi y'all. After finding bad fuel full of sediment downstream of the fuel pump on a '66/292 that I have owned for 15 years, I yanked the tank and found a very small leak in one of the corners, and a corroded sending unit. The gage has never worked. My mechanic tells me he could etch and seal the inside. The chemicals for this are $120 but he has chemicals from another tank. I found a replacement tank at Classic Industries for $150. I am wondering if anyone has experience with sealing the inside. I did a similar operation on a hypolon inflatable raft years ago and thought it worked well. Also, is the a visible difference between the 30 and 90 ohms sending unit. The replacement sending unit on websites is described as the 0-30 ohms. Thanks for the help.
Top
#1007475 - Sat Feb 15 2014 02:06 PM Re: Ohm resistance for fuel gauge / sending unit [Re: chopperguy16]
bartamos Offline
Loc: AZ
If a replacement tank is only $150, that is by far better. you will "mess" around with that tank, they will mess around with it and you will never know if all leaks are fixed and if they just coated over some rust/varnish. Subtract what they will charge from $150, that's your decision number. Three different vendor websites indicate 30 Ohm up thru 66. One site says ...."and some 67". If you buy one for a 1966 and it does not work, they will take it back because you did nothing wrong as long as gauge is original or equiv.
1960 GMC K10 Shortbed Wideside BBW CC V6
Everything I say is subject to "change". Pay what you can.
My opinions may not reflect management's opinions. (but not on purpose)
Close cover before striking.
Top
#1007480 - Sat Feb 15 2014 02:27 PM Re: Ohm resistance for fuel gauge / sending unit [Re: chopperguy16]
mycajah Offline
Loc: Texas
Thanks for the help. Once I put the tank in my basket, it went from available to out of stock. I'll get the 30 ohm sending unit and look for a tank thru the weekend. If I don't find one, I will give the chemicals a try.
Top
#1007501 - Sat Feb 15 2014 04:34 PM Re: Ohm resistance for fuel gauge / sending unit [Re: chopperguy16]
bartamos Offline
Loc: AZ
There are other vendors who do have the tanks at that price. Like Classic Parts of America, a sponsor here. Shipping is about $50.
Top
Moderator:  Hambone, sixtyfive c-10
