The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Stovebolt Supporter!
Spring is here!
If you are bringing the old truck out of winter storage, or up from the woods, be sure to check the Tech Tip for a few helpful hints.
If you have some work to do before you go cruising, be sure to check out what parts you need from American Classic Truck Parts. They still offer a 10% discount to Stovebolters.
Stovebolt On!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
Who's Online
51 registered (52Carl, 1953 panel, 55 SHAKER, 53Movinon, 49choptop, 4 invisible), 641 Guests and 6 Spiders online.
Forum Stats
39,628 Registered Members
48 Forums
105,652 Topics
Most users ever online: 940 @ Tue Apr 04 2017 09:52 PM
Today's Birthdays
knarfm, knarfm6460, norm wright, tyman00, wayne macklin
Image Posting Policy
Page 1 of 2 1 2 >
New Reply
Topic Options
#1209358 - Sun Mar 19 2017 02:42 PM 1937-38 Chevrolet Truck Inside Fender Panel Brackets
6cylindersovertexas Online
Loc: Beautiful Uptown Hurst, TX, on...
I have seen bracket extenders that weld on the top of the existing bracket as a replacement for broken brackets. They re about half the height of the full stock bracket with a foot to bolt them to the frame rail. Anyone have a source for this item or know of a reproduction part that is made as an extender item or whole new bracket item?
Thanks for any help!
_________________________
See Joe Fuchs' 1937 Chevrolet 1/2 Ton Pick Up on Facebook at The Top Of My Page. Go to: Joe Fuchs on Facebook
Top
#1209390 - Sun Mar 19 2017 05:06 PM Re: 1937-38 Chevrolet Truck Inside Fender Panel Brackets [Re: 6cylindersovertexas]
Wayne67vert Offline
Loc: Seminole County, FL
Joe,
My brackets were broken and repaired sometime during it's life. It appears they used some type of 'L' bracket welded to the fender liner bracket and then bolted to the frame.
Wayne
1938 1-Ton Farm Truck
More pix on Photobucket
Top
#1209477 - Mon Mar 20 2017 08:36 AM Re: 1937-38 Chevrolet Truck Inside Fender Panel Brackets [Re: 6cylindersovertexas]
MPandC Offline
Loc: Leonardtown, MD
Joe, for those of us unfamiliar, have you got a picture of the bracket you could share? It may be a simple fabrication to make a new one and eliminate any/all rust..
Robert
MP&C Shop Projects-Metalshaping Tutorials
Top
#1209563 - Mon Mar 20 2017 06:54 PM Re: 1937-38 Chevrolet Truck Inside Fender Panel Brackets [Re: 6cylindersovertexas]
Wayne67vert Offline
Robert, here are what mine look like:
click
click
Wayne
Top
#1209589 - Mon Mar 20 2017 08:53 PM Re: 1937-38 Chevrolet Truck Inside Fender Panel Brackets [Re: 6cylindersovertexas]
MPandC Offline
Is the original a pressed sheet metal, and if so, what is the gauge? Or is that a tube/pipe in the middle?
Robert
Top
#1209619 - Tue Mar 21 2017 04:52 AM Re: 1937-38 Chevrolet Truck Inside Fender Panel Brackets [Re: 6cylindersovertexas]
Wayne67vert Offline
It's formed in that shape, thicker than the fender metal but thinner than the frame. No pipe or tube in the middle.
Wayne
Top
#1209621 - Tue Mar 21 2017 06:21 AM Re: 1937-38 Chevrolet Truck Inside Fender Panel Brackets [Re: 6cylindersovertexas]
MPandC Offline
Anyone have one intact enough (original) to use as a pattern? I can see if I can make some on the Lennox...
Robert
Top
#1209862 - Wed Mar 22 2017 02:14 PM Re: 1937-38 Chevrolet Truck Inside Fender Panel Brackets [Re: 6cylindersovertexas]
goneagain Offline
Loc: north Idaho
this is the best one I have. its 3/16 thick. Not sure if its the left or right side. 37-38 fender support
Why work on one truck when I can work on two and get half as much done.
1937 Chevy 1/2 ton panel
1938 Chevy 1/2 ton pick up
Top
#1209868 - Wed Mar 22 2017 02:39 PM Re: 1937-38 Chevrolet Truck Inside Fender Panel Brackets [Re: 6cylindersovertexas]
MPandC Offline
Are left and right side different? Mirror image? Are you sure it's 3/16? That would be too thick to form on my machine, but in comparing to your tape measure in the picture, that looks more like 3/32 from here thumbs_up
Robert
Top
#1209880 - Wed Mar 22 2017 05:15 PM Re: 1937-38 Chevrolet Truck Inside Fender Panel Brackets [Re: 6cylindersovertexas]
goneagain Offline
Loc: north Idaho
Yes mirror images.and yes 3/32. I could send it to you if it would help. The other ones I have are ugly. The one flange with the washers welded on it all break off.
Top
Page 1 of 2 1 2 >
Moderator:  Fourbrads, HandyAndy1947
