Search the 'Bolt - over 60,000 pages of info. Start here if you're hunting!
Discussion
Forums
More than 18,000 registered
Stovebolters
from around the world talking old trucks.
The
Swap Meet
Over 2,380 old truck
stories with photos from Stovebolters worldwide!
Tech
Tips
Helpful truck restoration, preservation ideas and project
stories
More than 725 useful sites for
information, parts, services, and a "publications library"
News
What's new around the 'Bolt! Check in here often!
Sagas,Feature Stories, The "Roadkill" Commentaries, "It
Ran When I Parked It" Photo Contests, Poster Contests, and some stuff we've
done here and there and don't know where else to put it!
Stovebolt
Office
Stovebolter Locator! FAQ's, Stovebolt Supporters, Contacting Us, About us,
and other pertinent administrivia.
Stovebolt Goodies
'Bolter wear and other goodies!
Return to the home page |
A lot of guys, updating their trucks' drivelines, ask about driveshaft pinion angles, shaft length, critical speeds and other related drivetrain stuff. A lot of info and advice out there is incomplete, confusing or just plain wrong. Here's Grigg with some straight dope on ...
Driveline Set Up
(01 March.2008)
By Grigg Mullen
"Grigg"
Bolter # 6590
1952 Chevy 1-Ton Longbed
1948 Chevy 2-Ton 5-Window
Lexington, Virginia
Duh!!! Read the Instructions!
Most people have a hard time understanding how a driveline should work. Therefore many people who think they know how to set it up are confused.
I have found that the best way for someone to understand how it works, and how to set the angles, is to read the instructions.
<< click image for larger view >>
These two manuals will help with all driveshaft installation and geometry questions. Personally, I have printed them both and put them in a notebook that's very handy:
Installation Guide, Roadranger manual number DSIG3311
This one is most useful when reinstalling or slightly modifying an existing driveline. It will help with figuring angles and ideal operating conditions.
- Spicer Driveshaft Applications Guidelines, Roadranger manual number DSAG0200
This one is most useful when designing a driveline from scratch. It will help with figuring critical speeds, max shaft lengths, and required component sizes for any given application.
The Basic Rules
Some important parts cut and pasted from the "Installation Guide" (second of the two links above):
- Rule #1 -- Universal joint operating angles at each end of a driveshaft should always be at least 1 degree.
- Rule #2 -- Universal joint operating angles on each end of a driveshaft should always be equal within 1 degree of each other (1/2 degree for motor homes and shafts in front of transfer case or auxiliary device).
- Rule #3 -- For virtual vibration free performance, universal joint operation angles should not exceed 3 degrees. If they do, make sure they don't exceed the maximum recommended angles.
Please read the manuals -- you will learn something and be glad you did!
Grigg
Good engineering is simply finding the right wrench to pound in the correct screw.
Adam Welchel, 1947 Chevy
| Be sure to check out our extensive Forums discussions -- from General Truck talk, Electrical Bay, Big Bolts, Panels and Burbs, Engine and Driveline, Paint and Body, Interiors, Tool Chest -- The Stovebolt Collective can help in your quest and walk you through the mire and magic of working with old iron! |
