Ricky Turner's1945 Chevy 1-Ton |
28 November 2005
#1297
From Ricky: Would you please add a picture of my 1945 Chevy 1-ton to Stovebolt Gallery. Over the last three years I have updated the chassis with a late-model Chevy 1-ton suspension, plus added a 350 Chevy motor and 700r4 overdrive transmission. On the outside and interior I have tried to leave everything stock. The engine compartment, as you can see below, is nothing fancy. The front and rear are out of a 1982 Chevy 1-ton. I've also included a picture of the front when I was working on it. The frame is from a 1953 2-ton Chevy. I narrowed the frame 1 7/8" to fit the rear end then cut the front end 3 1/2" to fit the frame in front. |
Keep up the good work on The Stovebolt Page. I get a lot of help and ideas there.
Ricky Turner
"wingedexpress1"
Bolter # 4431
