Kevin Laymon's
1950 Chevrolet 6400 2-Ton Dump
14 February 2006
# 1423
From Kevin:
         I purchased this 1950 6400 2-ton truck last summer. As you can see, it has the rock dump bed. This truck appears to be about as original as you can get. It is straight with no rust and the odometer reads 76,000 miles. It came from La Crosse, Kansas where it had always been kept under shed. It has the original sun visor sleeve showing driving instructions. The original owner's manual was in the glove compartment along with some receipts to the original owner dating 1957 and 1961.
         The truck runs really good and the dump bed works great. I've included some pictures of the truck and a few takes of the owner's manual. Chapter 1. Engine and Carb. Lubrication. Technical Data and Specs. Adjustment Specifications.
Kevin Laymon
Andover, Kansas
