Lee Aanderud's1965 Chevrolet C-10 |
14 March 2007
# 1876
From Lee
This truck was purchased on October 17, 2006 for $1600. It was located in a suburb of Dallas, Texas and I picked it up on November 4, 2006. The truck came with factory A/C, factory tachometer, and a big rear window. It also came with an interesting brush guard that I probably won't put back on.
The truck had a 1966 Chevrolet 327 car engine and 3-speed manual transmission installed but neither had been run for quite some time.
My plans are to do a complete restoration of the truck to "driver" condition. But I will replace the Chevy engine with a rebuilt 331 Hemi from a 1954 Chrysler New Yorker. The original plans were to cut the truck down to short bed specs ... but after seeing Van Pershing's C-20 truck, I quickly changed my mind. Now the plans are to make a truck similar to his. Adding saddle tanks and filler doors will break up the long flat space between the cab and the rear wheel ... which I never liked and was the main reason for wanting a short bed.
For more information on my web site : pictures sent by seller prior to purchase (10/06); truck pick up and delivery (11/05/06); moving under it's own power (12/03/06); cleaned gauge cluster and added a Pontiac vacuum gauge (01/07/07); bed removal and rear end clean up (01/15/07); rear suspension rebuild and rear frame painting (01/27/07); 331 Hemi engine test fit - Day 1 (02/25/07); 331 Hemi engine test fit - Day 2 (02/27/07).
Thanks.
Lee Aanderud
"LeeA"
Bolter # 12459
Lexington, South Carolina
